I am struggling to get one of my pedals off. I have now stripped my crappy pedal tool and taken all the skin off my fingers. Any suggestions?
Tried to use a shifting spanner but I am scared of stripping the peddle.
It is a crank bros.
I've had similar problems before. Try heating up the crank (you can just pour boiling water over it a few times) where the pedal is, after a few minutes it should come loose... Worked for me after I'd tried everything else! (and make sure you're turning it the right way..)
istn there and allenkey ,or wateva u call it , hole if you look out from your chainring...inside of crank arm,... um i thinks thats an alryt explanation
Ther is an allen key slot. I tried that to no avail. I am truning in the right direction, checked with another peddle.
Gonna go and try the boiling water option.
Ther is an allen key slot. I tried that to no avail. I am truning in the right direction' date=' checked with another peddle.
The pedal you are checking is the same side I presume. If you need more leverage over the allen key get a ring spanner, normally about a 13 or 14 and loop the ring over the allen key to extend the lever.
YEs, I'm on the end of my seat wondering what you did! Was going to suggest trying a pipe if you have one. It's always worked for me but obviously it doesn't help if your spanner is fooked.
Cut cut cut
Excuse all the previous typos' date=' I was to furious to think!
Clearly still furious.
There is no room in mechanics for anger. Patience will always see you through something that seems impossible, counter-intuitive or just plain hard. When in doubt, put it on the back burner and think about it whilst doing something else.
I see too many stripped bolts, buggered spanners, bent allen keys and raped components.
I also had this problem on the weekend. Went and got myself the Pedros pedal wrench and used a bit of force. My problem was crappy spanners that were rounding from the force required.
