36 hole on a MTB is a bit of an overkill. Unless you are very, very heavy or load your bike with heavy touring stuff, a 32-hole is perfect. It is also the standard and getting 36-hole rims and hubs is problematic and limited in choices.
36-spoke on a road bike has some merit for tourers. But that's it.
Strangely enough, 28-hole is even more problematic on a MTB since there is just about zero choice there.
It seems that a lot of the Giants are coming with 28 spoke wheels. A bit annoying as I feel that the wheel is a bit delicate for my 100kg  body. Maybe its just mental, but I would feel better with a 32 spoke wheel.
I also noticed that the spokes contact the rim at an angle - not at 90 degrees. I hope I dont have long term hassles there...
TX for the info.  I'll get the 32 holes hubs.
Also what is meant by 3 cross / radial / 4 cross spokes in the wheel?
Which option should I go for on a MTB?
Radial 3 cross and four cross are the spoking patterns
radial is a spoke that doesnt cross any other spoke on the way from the hub to the rim
3 cross is where a spoke crosses three other spokes on the way to the rim from the hub
four cross is mostly done on tandems to add strength and it crosses four other spokes before getting to the rim
the most common on mountain bikes is three cross and is plenty strong enough for any normal rider!!!!
