Nope the std skewers that are on my pro light wheels old frame cinelli new frame Raleigh ltd
There is your problem. It's your wheel protesting about the change in frames.....
Inspect the frame carefully,I also had a ticking noise and eventually it came down to the chainstay that was cracked close to the bottom bracket shell that was causing the noise. Malkie2009-03-04 02:05:27
Thanks for the replies i have my bike with me today, taking it to the lbs jst now, will let you know the outcome, i checked the frame i can't see cracks unless i'm blind but all seems fine.
