Okay, I know you've all been waiting for this Wink
Here are my numbers from the Epic.  I'm busy with the mother of all blog entries which should be done over the weekend.
Enjoy!
Prologue:
Duration:   54:22:00
Work:       732 kJ
TSS:        70.5 (intensity factor 0.882)
Norm Power: 291
VI:         1.3
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   16.28 km
Elevation Gain:     594 m
Elevation Loss:    621 m
Grade:      -0.2 %  (-28 m)
Min Max Avg
Power:        0 687 224 watts
Cadence:      21 124 76 rpm
Speed:        0 55.2 18 kph
Pace          01:05 00:00 03:20 min/km
Altitude:     144 410 271 m
Crank Torque: 0 166.3 28.7 N-m
 Stage 1 (Gordon's Bay to Villiersdorp):
Duration:   06:38
Work:       4420 kJ
TSS:        363.7 (intensity factor 0.74)
Norm Power: 244
VI:         1.32
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   116.158 km
Elevation Gain:     3451 m
Elevation Loss:    3110 m
Grade:      0.3 %  (342 m)
Min Max Avg
Power:        0 800 185 watts
Cadence:      15 135 74 rpm
Speed:        0 63.3 17.5 kph
Pace          00:57 00:00 03:26 min/km
Altitude:     4 1089 496 m
Crank Torque: 0 177.4 24.2 N-m
 Stage 2 (Villiersdorp):
Duration:   05:22
Work:       3518 kJ
TSS:        270.9 (intensity factor 0.72)
Norm Power: 237
VI:         1.27
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   102.291 km
Elevation Gain:     2352 m
Elevation Loss:    2353 m
Grade:      -0.0 %  (-2 m)
Min Max Avg
Power:        0 780 187 watts
Cadence:      15 137 75 rpm
Speed:        0 58.6 19 kph
Pace          01:01 00:00 03:09 min/km
Altitude:     203 573 336 m
Crank Torque: 0 192 24.2 N-m
 Stage 3 (Villiersdorp to Greyton):
Duration:   04:39
Work:       2442 kJ
TSS:        222.4 (intensity factor 0.691)
Norm Power: 228
VI:         1.57
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   68.915 km
Elevation Gain:     2444 m
Elevation Loss:    2601 m
Grade:      -0.2 %  (-157 m)
Min Max Avg
Power:        0 764 145 watts
Cadence:      16 139 74 rpm
Speed:        0 69.8 14.8 kph
Pace          00:52 00:00 04:04 min/km
Altitude:     221 984 494 m
Crank Torque: 0 174.6 19.1 N-m
 Stage 4 (Greyton):
Duration:   05:55
Work:       4207 kJ
TSS:        330.8 (intensity factor 0.748)
Norm Power: 247
VI:         1.25
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   119.783 km
Elevation Gain:     3336 m
Elevation Loss:    3336 m
Grade:      -0.0 %  (-17 m)
Min Max Avg
Power:        0 686 197 watts
Speed:        0 73.9 20.3 kph
Pace          00:49 00:00 02:57 min/km
Altitude:     165 653 285 m
Crank Torque: 0 186.7 25.7 N-m
 Stage 5 (Greyton to Grabouw):
Duration:   05:36
Work:       4152 kJ
TSS:        302 (intensity factor 0.733)
Norm Power: 242
VI:         1.18
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   115.228 km
Elevation Gain:     2930 m
Elevation Loss:    2853 m
Grade:      0.1 %  (78 m)
Min Max Avg
Power:        0 666 205 watts
Cadence:      16 130 75 rpm
Speed:        0 68.4 20.6 kph
Pace          00:53 00:00 02:54 min/km
Altitude:     43 587 311 m
Crank Torque: 0 195.7 26.7 N-m
 Stage 6 (Grabouw):
Duration:   04:46
Work:       3211 kJ
TSS:        236.7 (intensity factor 0.704)
Norm Power: 232
VI:         1.24
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   85.284 km
Elevation Gain:     2250 m
Elevation Loss:    2262 m
Grade:      -0.0 %  (-13 m)
Min Max Avg
Power:        0 823 187 watts
Cadence:      16 131 75 rpm
Speed:        0 68.5 17.9 kph
Pace          00:53 00:00 03:22 min/km
Altitude:     115 541 329 m
Crank Torque: 0 163.4 24.1 N-m
 Stage 7 (Grabouw to Laurensford):
Duration:   3:44:29 (3:46:23)
Work:       2436 kJ
TSS:        198.5 (intensity factor 0.728)
Norm Power: 240
VI:         1.33
Pw:HR:       n/a
Pa:HR:       n/a
Distance:   62.498 km
Elevation Gain:     1855 m
Elevation Loss:    2054 m
Grade:      -0.3 %  (-199 m)
Min Max Avg
Power:        0 704 181 watts
Cadence:      15 125 75 rpm
Speed:        0 68.8 16.6 kph
Pace          00:52 00:00 03:37 min/km
Altitude:     93 777 392 m
Crank Torque: 0 159.7 23.1 N-m
I suspect stage 3 was the stage which involved the long portage which would have resulted in a lengthy period of zero watts.
Would be interesting to see Bruce's PMC and where his TSB ended up.
Bruce, I thought that MTB was supposed to be harder than road? Those stats indicate that you grafted much harder on the 94.7 than you did for the Epic. Is that because your average includes zeros?
What happened to your partner Bruce?
My partner had a cyst (saddle sore) removed about a week before the race.  It was a bit of a gamble, bit the risk of the saddle sore getting infected was worse.  The stitches were removed on the Wednesday, but the wound opened during the prologue.  He changed his sitting position on the bike to try to keep off the wound, which ended up casuing him severe ITB!
I've never seen MTB PT files - interesting the high VI's (and what was that loafing on Stage 3 about?? Wink)
This must have ramped up your CTL quite a bit!!
103 to 130 in 8 days Ouch
Apart from the walking, the portage section put serious wear and tear on my shoes - brand new Bontrager's which cost me almost R3k!!
TSB ended up at -75 at the end of the race.
OMW, that's sh*tty luck. Like the stats, always wondered what Mtb stats would look like. I always thought I ride harder during Mtb events but the EPIC is long stages so you have to kinda ride Tempo pace, is that what you did Bruce??
Bruce' date=' I thought that MTB was supposed to be harder than road? Those stats indicate that you grafted much harder on the 94.7 than you did for the Epic. Is that because your average includes zeros?[/quote']
Nah, it's because 94.7 is a 2h20 race and the Epic is 8 days of between 4 and 6 hours Wink
OMW' date=' that's sh*tty luck. Like the stats, always wondered what Mtb stats would look like. I always thought I ride harder during Mtb events but the EPIC is long stages so you have to kinda ride Tempo pace, is that what you did Bruce??[/quote']
Ja, I was also riding with a partner that was struggling physically and the main aim was to get him to the finish - no point in being on the rivet and then not finishing.
The last few days I rode alone, but they put me right at the back and I had to work my way through the field every day - so it's not easy to get motivated to drill it when you are standing in a queue of riders on a single track!
Hey Bruce. Thanks for interesting stats on Epic. Daily TSS incredible! On Borriz,s post yousuggested 4 minute intervals- any reason for specifically 4 and not say 3 or 5 minutes?. Lastly, please post stats on Argus , when you get some timeClap
My partner had a cyst (saddle sore) removed about a week before the race.  It was a bit of a gamble' date=' bit the risk of the saddle sore getting infected was worse.  The stitches were removed on the Wednesday, but the wound opened during the prologue.  He changed his sitting position on the bike to try to keep off the wound, which ended up casuing him severe ITB!
For those who end up with a similar problem. the classic and best solution is to cut a piece out of your saddle so that the sore or wound rest in that hole and thus is not pressured.
That if you insist in keeping riding.
Hey Bruce. Thanks for interesting stats on Epic. Daily TSS incredible! On Borriz' date='s post yousuggested 4 minute intervals- any reason for specifically 4 and not say 3 or 5 minutes?. Lastly, please post stats on Argus , when you get some timeClap[/quote']
No problem with 3 minutes, or 5 minutes. Generally intervals that target power at VO2Max are around 3 to 8 minutes.
The shorter the duration, the more contribution comes from anaerobic energy pathways, and hence shorter duration intervals (3 min) will stress anaerobic systems more. Whilst longer duration intervals (say 8min) will stress aerobic pathways more, and will be more influenced by lactate threshold limitations.
The best rule to apply is to take a look at the races that you typically do and the duration of the climbs. Also, look at whether you struggle more on shorter, high intensity climbs, or longer drag type situations. That gives an indication of what you need to work on.
4 minutes is just a nice duration that targets VO2Max very well.
