Is it possible to use a 140mm rotor at the rear with a standard XTR caliper or is a special caliper needed? Maybe a different mounting bracket?
No need to. I will post you photo of my set-up if you want.
Konaman - yip I understand that but wanted to do it without having to buy another 'front' caliper for the rear .....
Onetime - Please sir, I would appreciate that!
But but but Onetime is that an XTR caliper intended for 140mm? The one I have is for a 160mm .......
No that is 160mm. For 140mm you will need a front caliper.
