bike maintenance
Ellistiaan
hello there hubbers!
first of all i would just like to say thanx for all the input and help u guys gave me with purchasing my first good mountain bike! i think i finally got lucky(bought an scott tampico which was almost brand new for 1700rand) you guys think its a good buy??
and then i pleeze need some tips on proper maintenance of my bike to ensure the best possible performance for the longest possible time... im so new to this sport
Thanx for all the help!
Link to comment
Share on other sites
There is a DVD that you can buy for R99 from bike shops - I don't know the name but it has a Bianchi 928 on the front cover. It has everything that you need to know in it.
There is nothing more satisfying than being able to fix your bike yourself - it just requires a littl patience!
Link to comment
Howzit, glad you came right.
There are many aspects of bike maintenance and the hub is an awesome place to get it. Any questions in particular or concerns you have. It generally helps to get the thread going.
Else keep well and hope to see you on the trails
Link to comment
I see the bike is a 9 speed, check out info on chain wear. Its a serious bugbear that can cost you a fortune if not looked after. You will need to measure your chain for wear. If you ride with a worn chain (will still look fine) you will damage your chainrings and end up replacing just more than your chain.
Link to comment
The DVD is called The definitive guide to bicycle maintenance.
Thanks for the reminder
Link to comment
No problem, I got a free copy with my bike.
Link to comment
Using the dvd and bike manuals such as park tool you can just about do every maintenance job and even build a complete bike from scratch, whether you want to is another story.
Link to comment
I see the bike is a 9 speed' date=' check out info on chain wear. Its a serious bugbear that can cost you a fortune if not looked after. You will need to measure your chain for wear. If you ride with a worn chain (will still look fine) you will damage your chainrings and end up replacing just more than your chain.
A worm chain works very well with worn blades . But I want to give my DT to Johan one day when I replace it for his expert opinion on it . A clean "stretched" chain is better than a new dirty one imho . smiley2.gif
Link to comment
Very true, ended up last night reading up about WD-40 and chains. Very interesting. Chain maintenance can get quiet complicated if you want to, but golden rule applies: Keep it Klean Thumbs%20Up
Did my own experiment about this: Road twice in Kogelberg with a very clean chain and it was great. Left it dirty on purpose and threw on some wet lube, well actually I drowned it. Let the dirt and grim build up for a few rides and the bike now sucks.
Link to comment
