But what's wrong with your current cables?
1. How much lighter can a cable really get?
2. How much stronger can it really be?
Any idea on pricing?
Hog yeah about 20-30g less.  Main thing is thats its kevlar type cord so no rust/corrosion and or stretch and fraying so theoretically they won't really need replacing...
That's not quite correct, over time the cables do stretch and fray, in my opinion they need replacing every 18 - 24 months. Du Point reccomends replacing the cables on a bi yearly basis.
Ok well I guess I was sold on the marketing hype, I really thought this would be allot better than normal cables.
But I went to my lbs today and got new Jagwire Ripcord Teflon coated cables for R100, so I think I can afford to get new cables when needed, it's really cheap IMO.
Teflon Cables.
Now that makes sense to meClap. And it wont cost a cable and life savings account either.
 Personaly im tired of oiling my cables after each muddy ride. Smile
Look theres nothing worng with PowerCordz, as with every thing they have there place. I'll be honest they'll cost you in the region of $40 a cable which is hellishly pricey. Most of the time they're founf on 5 KG MTBS and such.Rather save the money and invest in other areas of your bike. You have a GT right? Real weight saving starts with rotational components. Wheels, shoes, cranks etc.
Yep 08 GT Zaskar Pro carbon, got it down from 11,6 to 10kg with pedals, 2 bottle cages, slapsock and watch/speedo mounted.  Main idea here isn't weight saving at all, better worry free shifting is... (or was hehe)
That's not quite correct' date=' over time the cables do stretch and fray, in my opinion they need replacing every 18 - 24 months. Du Point reccomends replacing the cables on a bi yearly basis.
Who is this Du Point oke? Some French guy?
Yep 08 GT Zaskar Pro carbon' date=' got it down from 11,6 to 10kg with pedals, 2 bottle cages, slapsock and watch/speedo mounted.  Main idea here isn't weight saving at all, better worry free shifting is... (or was hehe)[/quote']
Then make sure you have a clean drivetrain and and clean gear cabling.
My fault I forgot the IO, its Io Dupont. Company that makes PowerCordz.
