So this is the situation. I bought a new Blackburn X4 light online from the US and it arrived today. Very eager to get it working (despite the summer weather) I plugged it in to charge and besides a red flicker for 0.5sec - nothing!!! The charger got warm and gave off a strange smell, but no constant red light to indicate charging.
So, can anyone advise what to do. Is it:
  1. Normal for there to be no red light while charging?
  2. The charger that's faulty?
If it is the charger, can I get a generic one to replace it or do I need to try and find another Blackburn one?
Please help....
  • Replies 39
Oh crap!!! NO!! Just checked the charger and it's 120V!!!!!!! Now what? Have I buggerred the charger up?
Yep you did!!! Try and get one that has the same output on 220V.
Typical - never use technology in a rush @ night!!!
Can I use a generic charger with the same output? Or must I get a Blackburn one?
Thanks OneTime for the help!!!
Thanks OneTime. I'll try Ellies tommorrow. I can get one from CRC but it's an additional cost and more time wasted. good thing it's not winter!!!
Thanks for all the help!
What kind of charger is it? If it's a simple transformer charger then you may be able to substitite. If it's a "smart" charger that gives constant voltage/current then you may have a problem. But even so you can get these.
Think it's the 'smart' charger. Any idea where I can find one? What sort of shop? Does it have to be the 'smart' charger?
If you cannot find a replacement give the old one to an electronics guru. Power supplies are not that hard to decode. The flashing lights in the light that indicate charging/full, suggest that it's a dumb charger - the brain may be in the light?
