I can get this from CW Cycles for R450 (BOTH)
http://www.cwcycles.co.za/product/blackburn-flea-combo-light
WILL IT BE GOOD ENOUGH TO RIDE IN THE DARK ON A GRAVEL ROAD???
Front LIGHT
Includes velcro strap for handlebar
Micro size rechargeable Li-Ion headlight
Uses four super-bright White Nichia? LED?s
40 lumen output
Patented innovative charging system uses any standard 1.5V battery
Flexible and compact mounting design
Normal, Overdrive, and Flash modes
Superlight at 17 grams
3 hour runtime steady, 6 hours runtime flash
Multiple mountin options
With USB Charger
Rear Light
Includes velcro strap for seat post
Micro size rechargeable Li-Ion tail light
Uses four super-bright Red LED?s
Steady, Flash, and Chase modes
6 hour runtime steady, 12 hours runtime flash
I use two of these for my early morning commutes. For their size, they are awesome! I used them for MTB night racing at Delta Park in December and they were fine. I don't think one would be enough on your gravel road. If you buy them make sure you get the new version that has the USB charger included. This let's you charge the light from any USB port on your PC, pure genius. I don't have the rear but if it is as bright as the front it will be perfect for commuting and other riding.
Oom pops.
Die goed is BAIE potent op die pad fiets......en ek sal met hom in die nag enige tyd ry.  Die karre bright my met hulle op.
MAAR.
Sal ek soos 'n malle jaag met die MTB op die grond in die nag waar ek elke dingetjie op die pad wil sien?
NOPE.
Popeye, jy kan nie eintlik daardie 2 ligte vergelyk nie.
Die magicshine is in 'n heel ander klas!
Dis nie perfek nie en jy kry beslis beter, maar hy behoort helder genoeg te wees om single track in die donker mee te doen teen redelike spoed.
Goeie waarde vir geld. (al is dit 'n 'Chinees copy' met heelwat minder Lumens as wat hulle beweer).
mountain_lion2010-01-14 16:28:11
