80mm Fork and 100mm Rear shock, can it work?
philip.maree
I have heard that the rear and front travel should be similar. Why is this?
I have a 80mm Fork and I am looking to upgrade my HT to a dual sus but the rear travel on a dual sus frame is 100mm.
philip.maree2010-01-14 03:23:03
Link to comment
Share on other sites
alot of 100mm forks you can just add a spacer and it will make it 80mm. Some 80mm might even have these in already so if you remove it it will be a 100mm.
Link to comment
alot of ROCKSHOX 100mm forks you can just add a spacer and it will make it 80mm. Some 80mm might even have these in already so if you remove it it will be a 100mm.
Link to comment
I have a rockshox reba sl 2008 80mm model.
What would the effect be of running 80mm travel upfront and 100mm travel in the rear?
Link to comment
It will depend on the frame you?re looking at.  Some full sussers are designed for 80mm forks.
The rule off thumb is that you will steepen the head tube angle with 1 degree for every 20mm that you drop in travel.  The effect is that the 100mm frame with a 80mm fork will be a ?bit? more ?twitch? (steer faster).
So look at the head tube angle of the frame your looking at.  Most are around 69-71 degrees.  Hardtails are normally 71 degrees. So it should not be a problem if the frame you?re looking at has a head tube angle of 69-70 degrees. Only a Giant Anthem can get away with a 72 degree head tube.LOL
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I build up an old Kona that feels like it steers slowly(wide) compared to my hardtailOuch.  I later found out that it should have an 80mm fork instead of a 100mm fork that it has now.
Link to comment
Thanks for the explanation Ox.
So it has more to do with the handling of the bike rather than the travel, correct?
Link to comment
Hey, My Santacruise Blur LT was probably designed for a 4 or 5'' fork, but I actually prefer the handling on 4'' the slightly steeper angle is much better for singletrack, I only put the fork on 5 for big gnarly DH
So ride the 80'' I recon It'l be fine
Link to comment
thanks for the question (and answers), was thinking of doing the same - my skareb 80mm fork can't be changed by spacers etc.
So which dually frame would work best with a 80 mm fork?
Link to comment
