I bought a set of deore 535 disc brakes from a hubber but the hoses are too short. I am about to order a few meters of Fibrax brake hose from CRC
Is the fibrax hose good for Shimano brakes?
Do I also need to order the olives and inserts, if so how many?
When I undo the holding nuts at both the lever end and the caliper end do I then just pull the old hose out?
Is this something that an inexperianced home machanic should be looking at?
