Hey all
So as you know im a compulsive fidler and never seem to be able to leave stuff stock..
I got the stans no tubes podium mmx wheelset a while back and want to replace the red Alu nipples with blue ones.
Would this be feasable from a rebuilding perspective as i've seen reports of guys 'dimpling' the rim when tensioning the spokes and I dont want that to happen.
Also what spec is needed - would these work ?
Thanks,
WW.
You would first need to know the current length of your nipples (and I'm not talking about arousing them first) before placing an order.
Sorry, I didn't hear my phone ringing.
The answer is yes. No worries about a rebuild on a wheel that is in reasonable condition. If the rim is really buggeredd, don't bother but it it OK and new, go ahead. There is no risk of dimpling, I don't know what they're talking about.
Secondly, nipple length is a strange one. You only need longer nipples for rims that have nipple access via a double-wall construction and the nipple head seats on the inside of the second wall. For instance, imagine a rim made of wood. The nipple head will seat on the one side and have to go through 15mm of wood before coming out the other end. Then you need a long nipple. If the nipple seats directly onto the bottom layer closest to the hub, you use the shortest nipples available - 10mm.
Longer nipples cannot compensate for too-short spokes either, since the thread engagement is still the same. Longer nipples are weak and undesirable. Blue nipples are an acquired taste but it works for WW.
