Been to 2 LBS and they can't even agree!!
One says you are not allowed to remove gears and insert specers - leaving 17, 19, 21, 23, 25 gears, rather upgrade the whole system to a 10sp and pay a whack of money.
The other says, remove the bottom 3 gears - grind the fourth and reset the RD to the gear limit - cost R250.
There is virtually no info on the CSA Website that I can find, and everyone has their own ideas.
I have already replaced the 53T chainring with a 52T.
I hope that this resolves the whole situation!!
Trail Snail2010-05-29 10:04:11
  • Replies 37
I found the same with LBS....they dont know much about Jnr. League racing let alone the gear ratios they use. Its simple...my son (U/14) uses 9spd, we removed 4 gears leaving him with 17, 19, 21, 23 and 25. spacers was inserted and the RD was adjusted - R100. The 52 blade should not have (Tiagra - new) been more than R250.
Result_52/17
Looks like Cycling is far cheaper in the WC than KZN!!Shocked
Cost of Tiagra 52 Blade = R310
Cost of Gearing change = R250
Total Cost = R560Angry
Or are the LBS's ripping us off??Unhappy
