I got an S-Works Epic 2008 and I put the GXP XX cranks Q160 on no problem at all,a straight bolt on using the new BB.
From what I understand the newer Specialized frames are Press Fit BB's so you would use the BB30 BB.
Is the bb on the bike press fit or traditional english thread??
I know some specialized bikes have an issue with the bearing size as mecnic pointed out.
If you have the 09 fsr stumpy then you have a normal BB and the GXP BB will work with the XX crank.If you have the stumpy HT 09 then you have a pressfit BB91 and you have to make a makeshift plan until truvative releases their BB91 bb in a months time.
