  Quote
Does one generate better power with or without front teeth' date=' or is that a weight saving excersize[/quote']
If it helps to remove a few, I am going to the dentist tomorrow!
The qestion is though which one to remove, personaly I think the back ones are heavier and will therefore result in a much bigger weight saving, of course also resulting in a better power to weight ratio, I dont knowOuch
The question is though which one to remove, personaly I think the back ones are heavier and will therefore result in a much bigger weight saving, of course also resulting in a better power to weight ratio, I dont knowOuch
  Quote
Without, definitely Big%20smile
  Quote
  Quote
Can you recommend a good dentist, or should iI just ask my misses to pop then out. Also do you recommend the front or the back, and at least how many. Also once they are out do you require somone to pre chew your food, does this aid in the digestion and will this improve my performance, and if so could this be considered doping, you know like a blood tranfusion.
  Quote
Bruce' date=' was there a race report for the Dischem?[/quote']
Yes! "We came , We saw , we concord!" Big%20smile
101%2007-09-27 04:20:44
  Quote
  Quote
and we are a bit gatvol of it by now, need some of that genetically altered meat they are supplying you.
The only thing at the moment I will beat you in is a spelling contest.
  Quote
Eish, I will be posting it in the next half hour or so - been head down writing my coaching exam Thumbs%20Up
It's doping, someone is chewing his meat(notice chewing, not sucking) due to his lack of front teeth, and he is been given an advantage due to this. We need to protest with CSA and have the meat tested.
