My wife weighs +-48kgs. In order for her fork (Marzocci Bomber TST air fork) to have enough give I pump it around 50psi when the recommended minimum is about 100psi. It worked well for a year but on the last two rides she finishes the ride and all the air has escaped from the fork. The last two rides were very muddy. It still pumps up fine - just at some stage in the ride it deflates.
Do you think?
1. The fork needs a service and then it will be back to normal (R500).
2. The fork is broken - buy a new fork.
3. Pump the fork to the minimum psi and it should be fine - the air leaking is because of the under inflation.
4. Something else.
Edited by Just Keep Pedaling
Contact Johan Bornman at www.yellowsaddle.co.za .... he does Marzocchi.
