Does anybody know whether or not there is a Course Download available for the Argus route for my Garmin Edge 500?
Ideally one that has waypoints scheduled for a 3hr finish.
  • Replies 35
Im also looking for a route download for the GArmin Forerunner 305 for sub 4.
I remember seeing them on the ARGUS website a few years ago, but I cant find it..
Please help, would really like to track my progress!
Guest coenie
Try searching connect.garmin.com
Just map it out on mapmyride and set the speed to 36.6 kph. that should give you a sub 3. Maybe set it to 37km/h so you've got some extra time. Then you can use garmin training center to add the waypoints
depends which one you want to use?
Latest SportTracks 3
or earlier SportTracks 2.1
3 is a trial version and has limited functionality until you buy the full package (you can import directly from your Edge500)
2.1 is a free version with many plugins still available (you would have to convert your .FIT files to TCX or GPX manually before improrting to ST, done easily with Garmin Training Centre)
  On 3/8/2011 at 12:30 PM, AIRMAVRICK said:
I basically just want to do what gman1834 said we can do. Will this work for my forerunner.
can you load cource *.crs file to you forerunner?
  On 3/9/2011 at 11:31 AM, Slowbee said:
as an aside, do the garmin 500, 705 and soon to be 800 files all work on the same units?
I think they all sould be able to uploade course files. I only have a edge 305 to test. :(
