Kan iemand my se wat is die beter shock tussen die twee
Fox F100 RL, 100mm travel, air spring, compression and rebound adjust, with LO, alloy steerer
of die
RockShox Recon Silver TK, Turn Key damper, Solo Air, alloy steerer, rebound adj., disc only, 120mm travel
one is 100mm, the other 120mm
Of the 2, I'd say the Fox is the better, purely because it's a better fork than the Recon. Better spec etc. But think on what type of riding you'll be doing, and then have a look at either a 100mm Reba RLT vs the 100mm Fox F100 or a 120mm Fox vs the 120mm Recon. The 2 forks will perform differently because of the different stroke length.
Die RL het nie compression adjustment nie op die Fox nie, dis die RLC.
DIe fox heelwat ligter en definitief beter, "plusher" mar as jy meer trail riding doen en nie race nie is die 120mm travel op die recon dalk n beter opsie vir jou.
