From the hope site:
We have a couple of noticeable changes on the hubs now - first one is that they all now run stainless steel bearings throughout, bringing them inline with Pro3. These means longer life, smoother, free running and even more value for money. With the bearing change comes a new axle. The old 15mm axle is now replaced with a 17mm version. This means total compatibility with Maxle and Maxle Lite (reg) 12mm bolt through. This hub features a one piece 7075 aluminium rotor body and pawl carrier. Four pawls engage into a twenty-four tooth steel ratchet which is fixed into the hub shell and is sealed with a frictionless, non contact labyrinth seal. The axle runs on five cartridge bearings. All Pro2 hubs are standard 6 bolt disc compatible.The hub shell is machined from a solid billet of 2014 T6 aluminium.
I'm running black pro2 evo's on my new ss and loving them!
