Advise on Triathlon's ( Gear, training, ect)
Xanderno9
Good day All,
Well I hope you guys have a blessed 2012.
I have decided that I want to take up triathlon up as a sport. I've been very fascinated with it for years now.
So if you guys can give me any tips on taking the 3 discipline sport on, I will really appreciate it.
Have a good 2012
Link to comment
Share on other sites
Get someone to help you swim propperly - swiming is 75% technique
Do brick sessions : bike/run - right after each other to get the body use to them
Enjoy the first one - after the second you will be hooked.
Top tip I ever heard - "Just remember, we still have to run after this"
Link to comment
I am doing the Xterra lite in a few weeks and have to agree with Vinny, I swam around 600m yesterday and said to my friend that if I like the tri's and decide to carry on then I will maybe go and have some swimming lessons to make it easier and less tiring.
Link to comment
Very good free training programmes on www.beginnertriathlete.com
I worked my way up from the sprint to 1/2 Iron distance in a year
Dont get swept up in the gear frenzy.
IMO basics are:
silicone cap
goggles
tri short/jammer
cycling shoes
helmet
bike
good running shoes
remember "no one ever says; lets play triathlon"
Link to comment
Send me your e-mail address I will send you a nice easy time based prog to follow - no rocket science degree required - as for equipment required see above from Pieter
Link to comment
thanks guys really do appreciate all you help.
Another thing that I'm contemplation is, should i buy a new bike or a second hand?
Something that't been playing on my mind, don't want to spend thousands on a bike and than I don't have any interest after a while.?
Hi saint my e-mail : xander.bronkhorst@gmail.com
Looking forward to the replies.
Link to comment
Hi Xander,
I'd suggest if you are a rookie, go 2nd hand 1st.
A new bike can set you back quite a bit.
You're also going to make all your rookie mistakes on your 1st bike - so better to have something you're not too sorry for.
When you start training and you build up knowledge about groupsets and saddles and such you will eventually know exactly what you want in a bike and then when you spend a lot of cash you get exactly what you are looking for.
Go out and have fun!
Edited by Spartan226
Link to comment
Always a tough decision. Borrow a mate's bike to train a bit and do a sprint tri is first place.
Better value for (less) money in secondhand market.
Buy a new (cheapish) bike and you like tri - you would like to upgrade quite early (remember the rule - don't get pulled into the tech stuff they have at tri's. It can be depressing seeing all the bike porn and compression gear there!)
Buy a new (cheapisn) bike and you don't like tri's nor cycling - you'll lose 40% of its value.
Link to comment
Probably your biggest worry as far as equipment is concerned is getting the correct running shoes. Chose wisely and spend wisely on this item.
I have seen many athletes on an old skadonk bicycle passing those on the latest technology - be patient when looking for a bike many secondhand ones are more than good enough to do the job - remember you don't buy a bicycle because of its resale value.
Tri bike or normal road bike - practicality states a normal road bike if you can only afford 1 bike - there is also no significant aerodynamic advantage in riding a tri bike unless you use a tri helmet and can maintain a speed of over 25km/ph - Clip on tri bars also work well on your road bike
Goggles and cap available from Mr Price Sport for under R100
Wetsuit - a entry level ORCA will more than suffice about R1600 for an S3
Link to comment
Start with the short ones, and a Olympic distance, for two seasons, then try 1/2 irm, then a year after that only tackle IM. With those big ones, you dn't wanna sit in transition 2, thinking"Oh my God, what did I get muyself into?" Its too late then.
Link to comment
Cervelo, you are making me worry. I only started during sept last year, have done 2 sprints and I entered 70.3. Hopefully I dont feel like that at T2.
Link to comment
If you completed 2 sprints easily and you are well prepared you'll be fine!
Don't hammer the bike and if you're feeling good when you start the run - HOLD BACK wink.png
Link to comment
Okay thanks for all the advise, really helping me.
Now with the running, any good brands I should be looking out for?
Also any other gear that I should look out for when it comes to the running?
Also, when it comes to a time watch, what do you suggest?
Link to comment
