Strava's power configurations are wrong when comparing to actual power readings from a SRM, PT or Quarq unit.
I've found they are reasonable for solo rides where there's not much wind (and provided you put in an accurate weight), but are completely nuts when you start including bunch riding and wind.
I found the estimate was within 15% (under and over) for the previous case, but overestimated power by 50% or more for races etc. where there was lots of bunch riding.
  • Replies 39
Edman you are correct, when I download my own files and then upload to Strava I wish I was pushing those sort of numbers and sometimes wonder why the numbers are so low for the effort. Its a cool app/site thou cause the times are accurate for segments so you can still honestly compare with others.
PS 90kg is brute heavy, I would say lighter riders are 60-70kg.
I consider myself heavy at 77kg
Well then, 96kg puts me in the Incredible Bulk category...
but I got a 3:03 this year and 2:55 last year, so it would be interesting to see my stats (If I had a PM)
Having said that, Chappies is always the end of my wheel sucking...
This will give you an idea on what level you are. These are the indications I was provided to compare myself
by the guys at cadencecycling.co.za
COMPARATIVE WATTS/KG for a 20min average
ENTHUSIAST 2,22
FAIR 2,75
MODERATE 3,29
GOOD 3,82
VERY GOOD 4,44
EXCELLENT 4,98
EXCEPTIONAL 5,51
WORLD CLASS 6,04
That sounds right, when we were rowing if you were achieving 5 or above you were knocking on the door for a world champs medal. Around 6 and you could almost taste it.
Would this 20min ave be balls to the wall or just riding fairly hard?
It would have to be balls, but agreed you cannot blow as you would have to take your ave watts for the 20min. No good taking a section where you worked hard.
i can relate to the amount of effort you have to put in on the climbs .... i come in at 95kg and did a 3h05 ..... chappies was also the end of the bunch for me :-(
SSISA is using a MAP Ramp test to determine watts / kg. I would guess this approach is a better control and more accurate accross the spectrum of riders as your output is less of a self-paced affair.
http://www.cyclingtips.com.au/2010/01/how-to-do-a-map-ramp-test/
They are interested in TT performance too (closer to but not quite consistently 'balls to the wall') but generally look at 40km as the duration, not 20 minutes.
Edited by Lucky Luke.
TdF Stage 2 Les Essarts team time trial – Chris Anker Sorensen |Full data - link below
One file that’s well worth taking a look at is the stage 2 team time trial. Chris Anker Sorensen (67kg) averaged 372 watts (396 normalized power) for 25:15. Sorensen rode on the front eight times at an average of 454 watts per pull. He led the team for five minutes and was “recovering” in the team slipstream for 20 minutes. His average watts while resting measured 336 watts.
If you were to turn this time trial into a race simulation workout you’d have to do eight, 30-60 second intervals at 120 percent of threshold, separated by 2-minute lower intensity efforts at 85 percent of threshold power.
http://home.trainingpeaks.com/races/saxo-bank-sungard/2011-tour-de-france/stage-2-team-time-trial.aspx
http://www.cyclingti...-map-ramp-test/
To be honest I am not sure the ideal way to do it in a cycling situation. It worked extremely well in rowing as our races are short. 6:00 - 7:00min so we could go flat out and get an average wattage. from there it is very simple to divide by weight and compare with athletes around the world.
Cycling is different in length and intensity, so what test would you use as standard? But the figures in that table resemble exactly what we would use in rowing.
Problem I have with a ramp test is first its designed to find VO2, second it doesn't really tell you if you are fit enough to win a race or tt at any particular level. where if you time trial 20mins and take an average, it gives you a far more accurate idea of where you are.
Also regarding the spectrum of riders and self pacing. It will be very clear that if you can't pace yourself to your max over 20min, you won't win a international medal.
Ramp test is not just a V02 test, also produces PPO not just V02. Its a accurate test and well used to determine factors like PPO, V02, Crossover, LT to name a few.
PPO? peak power output? and lactic threshold. I am not dissing the test I have done many. The point was in reference to the watts per kg and the 20min test, also the table that was provided. I still maintain that the test would need to be done as a time trial and the average watts used if you want to compare yourself to elite athletes.
Wow that is impressive for that weight. Were you with the bunch then over Boyes
ENTHUSIAST 2,22
FAIR 2,75
MODERATE 3,29
GOOD 3,82
VERY GOOD 4,44
EXCELLENT 4,98
EXCEPTIONAL 5,51
WORLD CLASS 6,04
These values are ones that were published by Dr. Andrew Coggan for functional threshold power (maximum power that can be sustained for a 1hr time trial).
The 20min test is one of the ways of estimating FTP (FTP is taken as 95% of the power in a 20min test). Coggan rates MAP testing as providing an equivalent estimate for FTP as the 20min test method.
You can read how Coggan compiled the list, as well as see lists for maximum power over 5min, 1min and 5s here:
http://home.trainingpeaks.com/articles/cycling/power-profiling.aspx
92kg 1.87m: 2h56 Argus with the first B's. Basically just had to focus at Edinburgh, Chappies and Suikerbossie.
Avg HR 156. Max speed only 69 kmph.
The weight and 11-tooth was a big advantage closing the gaps going down Smiths and Suikerbossie. ;-)
The rest as they say was a breeze!
