Rockshox Revelation - remote lockout oil leak.
I have a 2009 Rockshox Revelation Air U-Turn that is leaking oil from the remote lockout connection. Anyone had this problem and know a 'quick fix'. Or is it a case of a full shock service??????
Ha ha then you should be fine...it shouldn't be in that position....
Rubber side down... :whistling:
OP - When last did you get the fork serviced? Most folk don't do this kind of maintenance nearly often enough...
In January, so probably due another service?
How much should a shock service cost? Can it normally be done by your LBS or do they have to send it away. Need to get mine done and just tired of being ripped off.
Some shops service in house - others send to the agent. I guess an oil/seal replacement service will be around R600-700 for a Fox or Rock fork. Yours may be more depending on whether it is the seal or hose leaking. Give Yellowsaddle a call.
