Hi , I am new to this great forum :thumbup:
First up I need some help, After cycling with a begginner bike for sometime now I will be upgrading this weekend. Please provide some advice and feedback. Here are a few bikes I am taking into consideration. Hope the info makes sense I copied from websites.
1) 2012 TREK 4500 DISC 21"
R4999.95
Colors
Matte Metallic Black
Gloss Metallic Black/Gloss Signature Green
Frame
Alpha Gold Aluminum w/semi-integrated head tube, formed down tube w/integrated gusset, formed top tube, monostay seatstay, forged dropouts w/rack & fender mounts, replaceable derailleur hanger
Front suspension
SR Suntour XCM w/30mm stanchions, coil spring & preload, hydraulic lockout, 100mm travel
Sizes
21"
Wheels
Shimano RM35 alloy center lock hubs; Bontrager AT-850 disc 32-hole rims
Tires
Bontrager XR2, wire bead, 26x2.1"
Shifters
Shimano Alivio M430, 9 speed
Front derailleur
Shimano Acera
Rear derailleur
Shimano Deore M591
Crank
Shimano Alivio M4308, 44/32/22
Cassette
Shimano HG20-9 11-34, 9 speed
Pedals
Wellgo alloy platform
Saddle
Bontrager Evoke 1
Seatpost
Bontrager SSR, 31.6mm, 20mm offset
Handlebar
Bontrager Low Riser, 31.8mm, 15mm rise, 9 degree sweep
Stem
Bontrager Race Lite, 31.8mm
Headset
1-1/8" threadless, semi-integrated, semi-cartridge bearings
Brakeset
Shimano M446 hydraulic disc brakes
Grips
Bontrager SSR
2) Fuji Addy 2.0 2012 R 5499
SIZES XS (13"), S (15"), S/M (17"), M (19")
COLOR(S) White/Red
MAIN FRAME A2-SL alloy w/ PowerCurve down tube, tri-shaped top tube, oversized seat tube and semi-integrated head tube, double water bottle mounts
REAR TRIANGLE A2-SL alloy w/ S-bend stay, cold forged dropout w/ CNC'D disc mount and replaceable hanger
FORK Suntour XCM w/ mechanical lockout, 100mm travel
REAR SHOCK N/A
CRANKSET Shimano Acera, 22/32/44T
BOTTOM BRACKET Sealed cartridge bearing
PEDALS Wellgo w/ steel cage, toe clips and straps
FRONT DERAILLEUR Shimano Alivio, 34.9mm
REAR DERAILLEUR Shimano Deore SGS direct mount, 9-speed
SHIFTERS Shimano Alivio Rapid Fire, 27-speed
CASSETTE Shimano HG20, 11-34T 9-speed
CHAIN KMC, 9-speed
WHEELSET Fuji custom 32H mountain disc hubs w/ Alex DP17 double wall rims
TIRES Hutchinson Toro 26x2.15 or Kenda 837F/848R ATB, 26x2.1" wire bead
BRAKE SET Tektro Draco hydraulic disc, 160/180mm rotors
BRAKE LEVERS Tektro Draco hydraulic
HEADSET Oval 1 1/8" semi-integrated, 30mm spacers
HANDLEBAR Oval M200R low riser, 31.8mm
STEM Oval M200 alloy reverse bolt technology, 31.8mm
TAPE/GRIP Fuji dual density kraton
SADDLE Fuji women's mountain-sport w/ steel rail
SEAT POST Oval M200, 31.6x350mm
WEIGHT 14.06 / 31.00
3)Axis A60 R3999.95
Frame - AXIS™ LIGHTWEIGHT, FORMED ALLOY FRAME. DISK SPECIFIC
Fork - SR SUNTOUR XCM V3 COIL WITH REMOTE LOCKOUT
Headset - VP DROP IN/ PRESS FIT
Stem - AXIS™ ALLOY COMP OS
Handlebar - AXIS™ ALLOY COMP RIZER 31.8/700
grips - VELO MTB
Seatpost - AXIS™ ALLOY COMP 31.6
Seatclamp - PROMAX
Saddle - AXIS™ COMP
Brakes - SHIMANO BRM-445 HYDRALUIC DISK
Shift Lever left - SHIMANO ALIVEO TRIPLE
Shift Lever right - SHIMANO ALIVEO 9 SPEED
Front Derailleur - SHIMANO ALTUS
Rear Derailleur - SHIMANO SLX
Crankset - TRUVATIV 3 X 44-32-22
BB - TRUVATIV
Pedals - WELLGO STEEL CAGE
Cassette - SHIMANO HG20 - 9 SPEED 11-30T
Chain - KMC Z-99
Hub front - AXIS™ DISK QR
Hub rear - AXIS™ DISK QR
Rims - AXIS™ DOUBLE WALL ALLOY
Spokes - STAINLESS STEEL
Nipples - BRASS
Tires - CST CAMBER 26 X 2.10
4) Brand: Schwinn Moab Elite Mountain Bike
The frame is a Schwinn Gold Series MTB double-butted aluminum with a Suntour XCM V3 100mm travel suspension fork with lockout. The front derailleur is Shimano Alivo and the rear is Shimano Deore Shadow which give the bike a 27 speed drivetrain. The gear shifters are Shimano Alivo Rapid Fire and the brakes are Tektro Draco hydraulic with 160mm rotors
Brakes: disc brakes
Frame: Alloy with replaceable drop-out
Freewheel: 9 speed cassette
Front derailleur : Shimano
Front fork : 100mm travel
Rear derailleur : Shimano
Rear Shock: No
Rim: Double wall
Shifter: Shimano 27 speed system
Tires: mountain bike
Hay the Axis components are also tops for the price.
Agreed..........you are going to battle to find something with the Axis price/value for money ratio
