Hi all
Is there a difference:
Hope Pro2 Hubs and as per:
http://www.buycycle.co.za/buyparts/wheelsets-mtb/custom-wheelset-ztr-crest-rims-hope-hubs-dt-swiss-spokes.html
and
http://www.hopetech.com/page.aspx?itemID=SPG258
Looking for a matching set of skewers:
Rear: 12x142 - I will get a skewer with the Frame.
Front: 15 Maxle - I will get a skewer with the Fork (Revelation, RCT3 Solo Air)
Most of my parts are either Hope, Thomson or Shimano based.
G
The Evo and pre-Evo front hubs are EXACTLY the same.
The Evo rear hubs have a larger axle and therefore different bearings. This allows it to be adapted to through-axle use as well as QR. However, if you don't use through axles on the rear, a non-Evo is better since it uses far, far cheaper bearings.
