Has anyone seen the wheel size article in the December issue of MBUK? They did a comparison over a 7Km trail with similarly spec’d bikes of the same weight and similar geometry. Pretty interesting results overall. The 29er came in first overall (21.23 min), 650b 5 seconds slower (21.28 min) and the 26” 29 seconds slower (23.52) than the 29er. So unless you are serious racer there is not too much in it. The surprise however is how close the 650b’s time is to the 29er’s seeing as the difference size wise between it and the 26” is so small.
