Narrow crank bolts for SS
doppelganger
Hi guys
I am busy sourcing parts locally. I will be using the One One chain tensioner, the Dartmoor Totem chainring and the DMR spacer kit.
Now my question is: where can I find narrow crank bolts locally. I see CRC have them but it will be a bit ridiculous to post a packet of bolts from overseas.
Any ideas?
Link to comment
Share on other sites
  • Replies 72
Ask for 4x derailleur hanger bolts from your LBS, or use some washers on the inside of the chainring.
Or file/grind down some longer bolts (the female side)
Or I think KCNC makes short ones that you can buy at your LBS - Shimano also makes some, I think some Dura-Ace bolts work.
Link to comment
Also remember 2 x 10 chain ring bolts are perfect . EG shimano xt work a treat .
Ask lbs too .
Thanx, that might be more readily available.
Link to comment
Will these Sprockets work? http://dialdbikes.co...e-sprocket.html
I see they mention: "Single Speed Cassette Sprocket for Shimano Pattern
Will I need to use only Shimano chains?
Contrary to what most shops will have you believe - almost any chains works in SSing.
That said - the worst possible thing in SSing is when the chain slips and you either smash your whatnots on the crossbar or try and kiss your front wheel at high speed.
The "standard" in SSing is a track chain - they're pretty cheap and nice and strong. It's a normal chain from a track bike - most shops should have them.
This is my favourite chain (for your next CRC order) - oh and my favourite chainrings...
http://www.chainreactioncycles.com/Models.aspx?ModelID=31548
http://www.chainreactioncycles.com/Models.aspx?ModelID=28730
I reckon this combo is the gold standard in SSing - I've used Shimano DX, DMR, no name brand and a variety of random sprockets with no issues at all with this pairing.
Link to comment
http://www.chainreac...x?ModelID=31548
http://www.chainreac...x?ModelID=28730
Quick question D, do you get quick link thingamabobs for those 7spd chains?
Link to comment
Fo sho. SRAM make one - also called the Powerlink like the 9/10/11 speed stuff.
Link to comment
Fanks exactly what I am looking for....
PS if you doing a order in the near future, let me know...I will be keen to join
Edited by rouxtjie
Link to comment
I asked CRC to ban my IP. Kinda like cutting up my credit card.
Here is the reason - should be in my grubby paws in the near future....
http://rbikes.com/merchant/482/images/zoom/t_AIR9RDO_Frame_NinerGreen.jpg
Link to comment
and I jizzzzzd in my pant...
there was a dutch guy at j2c with one.....uber sexy
Link to comment
Save yourself time and effort and get hold of Grant Usher www.singlespeed.co.za
Set of bolts is around R120 and you get different colours.
Link to comment
Man - when is the Crusher getting that site up and running again. He had some trick stuff on there!
Link to comment
