Fox Rear shock eyelet replacement
Alouette3
I just got a trance x2 (2010)
I have a worn DU bushing and LBS want R350 for a new bushing... where else can I get one that will fit?
You get from Droo or Stoke
any link?
I contacted Onico yesterday and all the guy told me was that the DU three piece system had been discontinued... no mention of an upgrade kit. The bike is with the LBS now so will see what options they come up with.
There is a standard upgrade kit available form fox as the DU bush has been discontinued contact your lbs to order you a set from the agents
Got my last DU bushings from Droo at Stoke, and did away with the 2 aluminium inserts (the cause of the rapid wear of the DU bushings) for a solid stainless bar that someone turned to the correct diameter for me, just with a little spacer ring slipped on each side to keep the shock centered.
"porqui" actually turned a couple solid bars out of brass that he is running on his Trance.
