Hi guys
Need some advice. Want to do the SS thing. Thinking of in porting a 29er (normal mtb frame) from China and then do the conversion. But I have heard some stories that with conversion you get a lot of chain drop. I have searched the web and cant find any SS carbon frames. Can someone please give me advice.
Hi guys
You haven't searched enough. Niner make carbon frames running an EBB...
Hey! The niner frames with the EBB are SUPER, and their steel frames are also really light. The EBB system is also superior if you want to have a rear disc brake, as you don't need to move the rear wheel to maintain tension as your chain wears.
Your chain won't drop if you tension it properly, and you can take extra precaution by using a single speed or half link chain.
Do you know where I can get a Niner frame.
