I have two MTBs
I prefer the Shimano SLX callipers with XT levers on my less used bike to that of the Avid 9 brakes.
can I swap the brake levers around, the question is , will the Shimano brakes fit OK on Avid Rotors?
I have two MTBs
Provided the rotors are the same size of course no problem, but why not swop the rotors as well seeing as you like the combo as is? Pretty simple to do unless of course one set may be centrelock and the other 6 bolt .....
Why would that be?
soem avid rotors are a bit larger than 180mm, even though they're advertised as 180mm.
Hence the word "may"
I know I had to do that for my wife's brakes, when I gave her my old avid rotors... She has Alivio brakes, which were 180mm.
Edited by cpt armpies mayhem
Ok makes sense!
Thanks Guys
Yip, that is the problem, the one bike has one bolt rotors and the other 6 pin screw in rotors.
Ok another question, I was given as a gift some new shiny XT levers, my current set up is SLX levers and callipers.
Will XT levers work with SLX callipers.
Thanks Guys
Yes. You'll just have to re-bleed the brakes once you've done the change-over, and get some new olives to put on the hoses. Your LBS will know what to do!
Thats great news.
the current SLX calippers 2010 model i think,the previous generation, the new XT levers are those shiny one arm ones, I take it this is no problem.
I do realise that it will require a brake bleed,I will get the LBS to do this.
The olive is a critical portion of the seal. Any time you're replacing hoses or calipers you need to change the olives, as they mould themselves to the shape of the calipers internal structure and may not conform to the new caliper / lever / hose and therefore form an incomplete seal.
From there you'll have an air ingress zone as well as a potential leak spot for the fluid.
So yes - they are a one use item.
You don't always need to replace the olive, I suppose best practise would be to replace everytime but it depends if it's deformed or not - give it a visual inspection if it looks good it should seal perfectly. The lip that the olive seals against is the same on all the shimano calipers and levers. I keep spare olives in case though so if I find one needs replacing I don't need to drop everything and schlep off to the lbs.
Edited by Skylark
