Got a irritating squeak squeak. Think the bearings have gone.
How difficult is it, anyone in the South of Jhb done it thats willing to watch over the shoulder, give directions.
G
Got to say looking at some Youtube videos the hub does not look like the easiest to service. or make easiest to stuff up rather.
G
Correct, it is the rear.
Do you have photos, guidance what needs to be done.
G
Eish I don't unfortunately...but its not a moerse job. Take endcaps of the hub....each of these will have a little o-ring rubber seal on the shaft of the endcap going into the hub....clean and grease. Then the freewheel body...very easy to remove and you don't need any special tools. All you basically do is turn the hub anti-clockwise and pull...if it is stuck and refuse to come loose...spray a little q20 in the freewheel body...NOT LOTS, just enough to lubricate.
Let it sit and work for about 10 minutes...then do the turn and push again...should just plop off. Regrease he o-ring seal in the freewheel. The hope hub's beauty is its simplicity....
Now telling it like that it actually sounds easy.
thanks
G
thanks
G
Ja promise you, the hope hubs are a pleasure to maintain and work on....very very simple design. Also while the freewheel is open it might be worthwhile to regrease and clean the pawls(4 little metal teeth thinga-ma-bobs)..but just a little, you don't want to dampen the sound of your hub...hahaha
Just found this on the Hope site,
Servicing Hope Pro 2 Evo's
G
Nah, i'll stop short of pulling the bearings out. Downloaded and safe for future reference.
nice reference to know exactly how it goes together.
G
That is a total rebuild though....if you want to replace bearing etc...handy vid ito how the hub assembles :thumbup:
Edited by awesme
thanks
G
It is actually that easy.
I did both my Pro 2 hubs on Saturday afternoon. Didn't take longer than 30 minutes.
Why so long? :)
It's dead easy - especially if you have the tools - the only one that really makes life easy is the seal replacement tool, otherwise you can kludge it with sockets - but I don't like doing that, because I find it damages the seal on the bearings sometimes.
Not that I do my hubs often.... no need on the hopes unless you like swimming with the bike.
Need to get my hands on a nice round cylinder with some teflon at the top to have the hub lie in.
Anyone access to a leith and that can cut Teflon as a bush also?
My 29er wheels I ordered also have Hope hubs so not a bad idea to tool up and skill up to service these.
G
