I regreased my front hub this morning, and cleaned up the cone and cups. I have adjusted the hub just right so that there is no side play in the wheel when i try put pressure on the wheel to the left or right.
My question is that, is it normal if when i squeeze the brakes tight the wheel moves slightly forward and back ? If i lift the bike in the air, and squeeze the brakes and move the wheel forward and back, all seems good. But when i put the bike on the ground and squeeze the brakes, i feel the wheel slightly move forward and backwards. But there is absolutely no side play which is good. Thanks for the help :)
Ps: my headset is perfect.
Edited by Azza
I can feel it when i hold the brak and take my hand and physically put my hand on the wheel and move it nacka nd forth.
Is the brake caliper tight? There could be a little play in the way the pads hold the disc.
What condition were the internals of the hub?
Edited by Mojoman
Conditiom was really good.
I believe it could be the oads moving slightly up and down when locked to the rotor...
Its the disc slightly slipping on the pads check your pads or give them a slight sanding with water paper
When sanding pads, place sanding paper on flat surface and run the pads in a figure 8 across paper until gloss dissapears and pad surface smoothed out
