I struggled with my rear xt brake which was spongy. Even after bleeding the brake from the caliper to the funnel it was still spongy. I then finally removed the caliper from the frame and then bled it from the top funnel towards the calliper. That forced a lot of air bubbles from the caliper. Feels like a new brake now :clap:
New Shimano brakes are not supposed to be bled bottom up - it blows the seal on the lever piston from time to time.
Funnel down is the only way to bleed the new brakes!
Glad I did not bugger the seals...Manual on their web site still shows bleeding from the bottom? :blink: Just glad it is working again.
Where do you get the funnel and/or the other bits and pieces needed for a bleed?
Edited by beanz
Just checked and the manual does show both ways - that is weird. Every Shimano employee I've spoken to locally says top-down!
@beanz - you should be able to buy a full bleed kit or just the funnel at any LBS - contact me if you're struggling. I'd recommend just the funnel - I use the funnel and some fish tank tubing to direct the used oil from the bleed nipple to an old jam jar.
I luckily received a funnel with my previous bike, but apparently they are hard to find. Then I just bought a syringe from dischem (R10) and some fish tank air tubing (R5). Just make sure to use the Shimano mineral oil. (R160/50mL)
Any mineral oil will do. Mineral oil is mineral oil after all. Much cheaper at motoring supply stores like midas etc. Edited by Sniffie
why? Castrol LHM+ works just as good and is R150 for a litre. as far as i have it the only difference is the color and the name on the bottle
Currect....one over eager thumb on syringe and pop goes the weasel....
Thanks Eldron
