No active topics showing on The Hub and Tapatalk
Tankman
There are no active topics when I am logged in and click on Active Topics?
There are also no topics on Tapatalk when I go to unread topics?
When I log out of my profile, I can see active topics??
Who broke the hub?
Something DID change - my enter key doesn't work anymore (Win7 & IE11). Not the only one having this problem either...
I had this before and switched over to firefox and it went away.
I see what you mean. on ?Tapatalk latest item is from the 30th, but other forums are fine.
According to my tapatalk, I have read the whole hub, into the future also because it has not changed in the last week!
I only use Firefox, Chrome is my second choice but I would rather use a Nokia 3310 before using IE!
Who broke the hub?
Tankman - can you check the settings on the New content page?
Link: https://www.bikehub.co.za/index.php?app=core&module=search&do=active
In the filter options bar on the left, scroll right to the bottom and make sure none of the filters are set:
- Just items I follow
- Items I participate in
- Items I started
If any are set they will be highlighted - click on them to remove the filter:
Link: http://www.thehubsa....earch&do=active
- Items I started
Thanks Admin
I am now starting to think that I am doing something wrong ... but what?
Tried different filters ... no luck ... no active topics. Not on the pc, not on Tapatalk
When logged in, this is all I see! I didnt fiddle with anything lately.
Tried the filters on 2 weeks, past month, unread, nothing seems to work
I would like to see is this, and this is what I see when I log out and go to active topics. But I want to be logged in!
Right at the bottom under "Other" you need to deselect "Just items I follow".
Currently it's set to only show new content from topics you follow - and if you don't follow any you won't see any.
Click on this to remove the filter.
Guest EdEdEd
Today - if I click active topics I get this:
Search is not enabled on the community at this time.
Need Help?
Need Help?
Should be back to normal now.
We disabled certain resource intensive services while our servers were getting back up to speed this morning.
