Converting a 9 speed to a 10 speed
CdT85
Hi All,
I am currently getting the components to upgrade my 9 speed (2010 Mongoose Otero Super) to a 10 speed. I have sourced (planning to buy still) most of the components needed (shifters, derailleurs, cassette. etc) but I am worried as to how to go about with my chain rings on my crank.
I currently have a FSA Alpha Drive Forged Alloy (22/32/42T) crank set. My problem is that I have an ISIS drive bb and I can't  fit a new crank set.
Will the spacing between the crank set gears be an issue? And I suspect I must replace the three chain rings if I go 10 speed?
Should I stick to 9 speed or is it worth my while to upgrade?
Thank you in advance
It may be a stupid question, but why do you consider 9 to 10 speed an "upgrade"? I have a 9 speed bike and am interested in your motivation.
You are currently, running a triple crank so you should have all the gearing range you need. Adding 1 cog in the rear will neither expand that range nor will it give you a new ratio.
How much will it cost and what benefit do you see?
Why this rather than a better set of wheels or fork?
I agree with Eddy. I'm running 1x10 on my one bike and planning on converting my 3x9 to 1x9 on the other. 9 speed components are half the price of 10 speed so why not stick with 9?
I actually want to upgrade my old, worn 8 speed groupset on my hard tail mtb, so decided to put my 9 speed  groupset onto the hard tail and go 10 speed on my full suspension. plan is to go single chainring in front then with a chainguide, seeing that I have constant issues with my chain comming off on the downhill sections.
Got a Shimano Deore XT 10 speed groupset from a fellow hubber for 1.5K which is not to bad in my book
You get better range with a 3x9 and prices are low, specially in used parts because of riders like you upgrading to 10 speeds.
I am happy with my 9 speeds set up and I keep buying 9 speeds XTR sets at great prices.
No need for a guide just get a narrowwide ring (from kitted.co.za) and a clutch derailleur (not compulsory) and off you go.
Thanx Orbit, I will take a look at that. trying to save weight on my heavy beast, so If I dont need a chainguide it will be beter
Only reason that promted the upgrade was my 2 x 8 setup on my hardtail that is kaput. And there is more 10 speed components available than 9 speed in the classifieds. So I decided to go 1x 10 on my full suspension and 3 x 9 on my hard tail.
So basically I'm transplanting my 9 speed setup to my hardtail.Am more than happy with my 3 x 9 setup.
I sat with the same issue to convert 9 to 10 speed on my 29'er... With all the components to upgrade, gets pricey! (unless you upgrade everything on budget quality)
Went to LBS and had them order a Shimano 12-36T 9-Speed cassette, arrived yesterday and has made the world of difference. Granny gear pedals as easy as my 3x10 26" and I'm running an SLX 38/26 crank on the 29'er. Cost was only a R370 upgrade (and the price of a new chain if needed). Don't have the need to change to 10 speed now.
Hey Charl
You can also get a narrow wide chainring from Rapide (Kiwi on here) for up front, I'm running one on my bike and have yet to drop a chain (touch wood) :)
I can get a Shimano Deore (HG62) 11-36 speed cassette as well as a Deore HG 54 chain  (both 10 speed), and plan to buy Shimano Deore XT shifter and derailleurs from a fellow hubber. Not sure if this is budget quality?
Havent forked out the cash yet. trying to find out what is best route going forward. I am happy with my 3 x 9 setup on my FS, but need a new setup on my HT. Current setup on my HT is a 8 speed Shimano Deore XT rear, with Alivio rapid shift triggers and alivio front deraileur...all cooked from wear and tear. My HT is a 2006 model and I am still running the same derailieurs, cant shift  up and down properly anymore
  • 3 weeks later...
Well, did my 1 x 10 conversion this weekend and took my bike out to Jonkershoek Sunday morning for a test run. Definitely a huge upgrade! Better gear ratios for climbing, 44/32/11 x 11-34 (old) vs 32 x 11 - 36 (new). Much lighter setup, and way more effective climbing. Thanx Roshambo for the components, My setup is sweet!
