How do I work out how much to increase stem length?
brucem76
Thanks - very helpful - something felt wrong for sure, cool to have someone confirm that my bars are way out....
Sorry but this is really very poor advice. What type of bike are you riding. XC, AM, "endure" rolls eyes, etc.
Stem length depends on how you need to be positioned on the bike for the type of riding and then there are anatomical constraints like length of arms, torso, flexibility etc.
Handlebar width has got F-all to do with numb hands, numb toes or numb nutts.
Eg I ride 61cm wide bars and don't suffer any of the above mentioned issues . Maybe I should get wider bars too just to please all the All mountaineers around Tokai.
  • Replies 179
wow helpful advise there... oh wait... helpful rant?
agreed to a point, Tim, but then wide bars make a helluva difference to handling, and if you're a big guy (like this oke is) then the wider the better.
Stem length should be the final consideration for a fit, tbh, and if you're choosing a long stem just to make it fit, you're stuck in the roadie mentality and have a frame that's too small for you
That's a rather big claim to make. Currently, there is not enough "space" for me to extend my hands onto the handlebars correctly. This results in me doing 2 things:
 - turning my wrists inwards to fit my hands on the bars
 - "scrunching up" my wrists to fit
Wider handlebars will address both of these, in my opinion. As will a longer stem. But nobody's raving about getting a longer stem. I'm quite happy to try wider bars (which are dirt cheap, and have other "happy customers") before I try anything else.
I'll keep you all posted.
Everyone I know has eventually gone to wider bars - some 720mm some 740mm and some 800mm and they are all much happier now including myself.
Getting a shorter stem has also helped combat that OTB feeling...
Jeez dude your brakes and shifters must be against the stem.
Look I agree with each to his own but I think that riding style is irrelevant considering his size and the width of the bar he is using. I mean, I'm half the guys size, and my bars are 720
I'm 187cm on a L frame and found that going from 720mm to 780mm on my current 90mm stem made my whole chest and arm position so much more comfortable, if a little too far forward now, and turning and control so much softer and easier. Waiting now for my 60mm stem to bring me back in to position again. What I would stress is that you make sure your seat position is correct before anything else................and just watch those fingers on narrow gates!
M2C
195cm has nothing to do with should width.
each to his own.
Hope those bars work out for you
It doesn't have nothing to do with shoulder width, it's just not directly proportional. And it has a lot to do with arm length too. I'll let you know how the bars work out, either way.
This is the one area that is very unclear to me everything else has pretty clear setup guides and even road bars have a measurable way to determine a width as a start.
I have searched before and I have not yet found any way where you can measure your shoulders/arms/thumb or anything else and come up with a starting width and then go from there I only find "wider is better" and the "wider is better is wrong" articles I have the dead hands issue as well and dont want to just buy and try. Then there is the whole its the sweep in the bars and not the width theory as well.
numbing hands is a symptom of too much weight on the hands because of pinching of the ulnar nerve.
It could mean theres a neck issue, lower back issue, bike set up issue. The bar width has absolutely nothing to do with these issues. Its not one magical cure.
Bar width suggestions are like prescribing panado for every ailment.
Wider bars have an advantage in leverage. In the OP"s case its likely the bikes cockpit is too long or too short. Too short a cockpit length will also cause problems because it results in a raised or hunched shoulder riding position. Too long a cockpit results in reaching for the bars and stretches and strains the shoulders.
Bars too low can also result in hand pain.
Thanks, that's useful info. At R199 for wider bars, I'm going to start by putting those on, and seeing what happens. Then, I'll go get all the above variables checked out at a fitting.
Numbing hands can also be bad positioning of the wrists i.e. bending the hands far backwards in relation to the arm - that's what I tried to focus on on my morning ride today (because I definitely bend my hands a lot) but when I straightened more, it felt like I ran out of space, and couldn't grip properly
Not sure how relevant this is but have you considered your specific bikes geometry. I recently put a 50mm stem and a set of much wider bars (780mm) on my bike and while the first ride was terrifying (twitchy and unstable) once I got used to it I realised I felt much better. A lot like moving to power steering at first you're used to pulling hard on the wheel but now that results in overcorrection. And I only invested R200 in the setup so I'm pretty sure it isn't purchase induced placebo. It feels like my bike was made for this setup now. I was specifically advised against going to a 50mm stem by a prominent bike shop but when I ignored them and did it anyway I was thrilled at the result. Sometimes you have to experiment a bit.
Halleluja. Someone with sense.
He needs wider bars before that. Ergo / bike fits generally focus on stem length only. If you have a short bar it'll throw out a longer stem requirement, which is a huge no-no for MTB.
where do you learn this BS?
