1X10 deraileur problem
timlee
Hi i have just decided to try out a 1X10 setup. I have 42t extender ring at the back and have a new shimano XT M786 deraileur.
I am having a problem in that the extender ring is very close to the deraileur and i am worried that its too close. Any ideas or suggestions as to what the problem could be and what a possible solution is would be much appreciated
Guest Smimby
Put the chain on and set the hi and low limit screw. Then use the B screw to set the distance away from the largest cog.
If you have fitted and extender 42t you may need to change the B screw for a longer one which you can get at any hardware store
Agreed, check the oneupcomponents.com website. When you buy the 42T ring from them you get a longer B screw with it.
He has put a longer b screw in its not the jockey wheel that's close to the cassette but the arm that that the cable joins to
It doesn't look like the derailleur is under tension?
Once it is under tension it should pull down.
Can you take a picture from the side.
Kitted also stocks B-screws
