Carbon frame issue help
mtbrider
HI Hubbers.
I have a 200km old 2015 Silverback Storm replacement frame that I would like to sell but after it was rebuilt I saw that the seat tube seems to be pinched by the f/d clamp. The bicycle shop had a look and showed it to the silverback agent who said its only cosmetic and that there is nothing to worry about.
My questions are: Is this a common thing & has been seen before and can I still sell it with a clean conscience.
Your inputs will be appreciated.
Regards
Stephan
I'm no expert, but that doesn't look merely cosmetic. I'd insist on a replacement.
Who would you insist on a replacement from?
Silverback would surely, and imo rightfully, say the damage was caused by over tightening the front DR.
So either the bike shop cause this, or the owner.
Not a manufacturing defect.
To the OP- I would say that's not cosmetic, so either sell it voetstoots, or get it repaired and build a spare bike...
To the OP- I would say that's not cosmetic, so either sell it voets toets, or get it repaired and build a spare bike...
Tell me how you know it is from an overtightened FD clamp, other than sucking on your thumb? If the FD clamp was tightened to the point that it cracked the frame, there would be clamp lines clearly visible on the frame, around that area. There are none that I can see.
My wife had a Stumpy HT that cracked in a very similar manner and at the same spot and Specialized replaced the frame, as the cracking was due to a manufacturing fault.
Valid point. Return to supplier.
My silverback syncra 2 frame had clinch marks from the FD, but they didn't look anything like this. It was merely the paint being squashed up a little. That looks more serious
Thank you for all the inputs so far. I am now definitely going to get another opinion about the frame before selling it.
What is that frame sold "voetstoots" worth?
Regards.
Do you perhaps have photos with those marks?
500 bucks or so. Only cos it can be fixed and I wouldn't call that cosmetic
Bloody shame. It's a gorgeous frame that Silverback.
Regards.
There is a guy call Bogus on the Hub that does carbon repair- send it to him and it'll come back brand new. Shouldn't be an expensive repair.
I have 2 carbon frames that were repaired and they haven't given me a days problem.
Then either sell it ( & disclose the repair), or build up a 2nd bike. Option 2 is always best- you can never have to many bikes!!
