Need a broken frame please
2 X 2
I want to build this.  Does anybody have a broken frame that you do not need anymore?  Obviously the back triangle and seat tube needs to be ok still.
I don't think the size is going to matter that much.  I think it depends on how high I want it to run. BMX frame will be low.  I might opt for a 26 frame.
If you use a steel frame it will make your welding a lot simpler and more durable.
I would love to see your plan for the 'tow hitch' link in more detail.
I still have to work that one out
This type of attachment apparently is very stable, over rough terrain and at speed. It has the swivelling joint directly in front of the cargo area. I suppose it is overkill for a little trip to the shop, but might be worth the extra trouble and cost if you intend to tour with it. They are expensive to import, but can be built if you are handy with welding.
