Garmin 810 not connecting to computer
Spirog
So, I've bought a new Garmin 810. I need to do a firmware update. However, when I connect it to the Windows PC (I've tried multiple) it isn't seen on the PC. The cable obviously works, because it's charging.
I'm getting irritated. Grrrr. Help please!!!
Yes. It's not seeing the actual device when I plug it in.
Is Windows seeing the device first? somtime I have Antivirus/firewall issues that stop it seeing the device.
Can you see the garmin as a hard drive through windows explorer?
And when you add a device in garmin express it does not see the 810?
Take it to Navworld in Strijdom park and your laptop if you cant sort the issue http://www.navworld.co.za/find-us/
No, I don't see the Garmin at all in Windows Explorer.
I suspect the cable is faulty, whilst it is charging the garmin the computer is not reading the garmin... try another cable
The Garmin appears not to go into storage/hard drive mode when plugged in. It switches on in normal operating mode.
I suspect the cable is faulty, whilst it is charging the the garmin the computer is not reading the garmin... try another cable
Had the same issue , 810 charged but I couldn't see the device on the PC , replaced the cable and it worked perfect .
Ok. I changed the cable and now it goes into mass storage mode. Some progress.
However, when I open Garmin Express it tells me "Garmin Express does not support this device. Please use Garmin Map Updater."
