Indoor trainer that fits 15mm through axle
Whatsup!
Hi All
I am looking for an indoor trainer. Nothing fancy, only to spend a bit of time peddling indoors.
I would like to be able to use my mountain bike with a 15mm through axle, but don't seem to be able to find one that can accommodate through axles.
Does anyone know of a basic Indoor Trainer that accommodates a through axle, or some sort of conversion kit.
Hi All
You should perhaps be more concerned if it fits a 29er with mtb tires on.... not many trainers do....
Of course - riding a knobblie on a trainer is a nightmare... don't know whats worse - the bum buzz or the noise.... :)
Chat to Dave at https://www.bicyclepower.co.za/contact/ - he will be able to help you with one that works for you.
Thanks.
Yip definitely would like it to fit a 29er.
Maybe there is a conversion kit to run a through axle wheel with a skewer (I will try research this) that can be used indoors.
Thanks.
There is a way - Dave has them ..... :)
Thanks.
If it helps, the Giant Cyclotron fits my 29er.. There is one for sale at the moment in the classifieds..
Thanks Raydek
Can you run a through axle on the Giant Cyclotron?
I can get conversions to run a through axle hub in a bike/frame designed for a skewer.
However I don't know how to run a skewer on a frame/hanger designed for a through axle, as it threads into the frame.
Your neighbours are going to think that you are drilling holes non-stop. That nobbles makes one hell of a noise... But hey, if you want to piss of the missus while she is watching her soapie, then go ahead at your own peril, lol.
Believe you me, I tried it and its not fun.. :eek:  :ph34r:
Thanks Raydek
I haven't tried, but I doubt it with the standard fittings on the Cyclotron.
I'll take some measurements later (ID of the cyclotron clamp things and OD of my thru axle) and let you know.. It might work if you grind the opening in the IDT clamp bigger for the lever of the thru axle to fit in it. And the other side clamp might fit over the knob in the frame that houses the thread, BUT if it does fit, it will most certainly damage/scratch the frame...
Will revert in a few hours.
I have the perfect solution for you..........Just buy rollers.......keeps your indoor cycling ummmmmm interesting  :whistling:  :ph34r:
I have tried rollers once, its much harder than it looks. keeping your balance and not trying to fall. .
Aggggggg please...........How hard can it be  :whistling:  :whistling:  :whistling:  :whistling:
Theoretically it should work, depending on the design of your thru axle... For mine to work I would need to cut the lever handle wider to accommodate it, but otherwise should work fine.
