I had a loose rivnut (without realising it).  Over time it enlarged the hole in the frame, and when I eventually got to the problem and tried to put it back, it dropped into the downtube - the downtube is closed on both sides.  It rattles when I am riding.  Ideally I would like to get it out, otherwise I will have to squirt some glue in there.  Any ideas or self-designed tools on how to extract it again through the small hole?
I'd agree with Mud Dee, tubes always have holes in otherwise welding wouldn't be possible with heat and pressure building up, but lets say that it is closed.
Turn the frame upside down with the hole pointing down....... and shake it like a Polaroid picture!
Widget.. thats a Micheal Flatery Fan Smile
Big%20smile - for all I know' date=' you could be right.!
[/quote'] I think you mean Flatley
Thanks for some of the suggestions.  Unfortunately the rivnut is aluminum, therefore not able to use a magnet.  Otherwise, the hole is very small, so you will not get it out by shaking.  Will have to design some sort of thing to loop it around rivnut when you get it close to the hole.  The frame is carbon, therefore the BB is closed - my LBS say that loose rivnuts on carbon frames happen fairly frequently, so one will have to look out for them.
Try get it to roll over the hole, get as much superglue on it as you can then turn the bike over and have it roll down to the BB. Hopefully it sits there forever. Those things weigh nothing, I've had a few replaced before.
