Frames that can accomodate 142+ hub rear wheel
GerrieTruter
Is there anyone that can tell me what 26" frames can take a 142+ rear hub wheel? I've been trying to get the information from the internet and clearly my google skills are lacking in that department. All info I got was that it's a Specialized specific issue but can't see what bikes in the Specialized range.
I bought a Roval Control SL Trail Carbon wheelset that has a 142+ rear hub, and I'm looking to maybe get a frame that would fit the wheels as it seems I might have difficulty selling the wheels.
Any frame that takes a 142 through axel will fit the wheel - cassette will be a few mm differently offset - should not be an issue practically.
From the Roval Wheel Instruction Guide
The dropout width looks the same, but the cassette is moved inboard by 2mm - probably to optimise the chainline for a 1x drivetrain.
Thanks for the information. So basically I bought a wheelset I won't be able to use.
What about a different rear hub and build it over?
Was thinking of it but the R4000+ its going to cost me to get the same quality hub and then the cost to rebuild is money I don't have at the moment.
Again as V12Man said those wheels will work in any 142 through axel frame and no I'm not just guessing or 'hoping' I have in fact done it. I used one of those 142+ hubs for a wheel build for my Jamis FS without any issues at all!
Any frame that accepts a 142 axle will accept a 142+ hub....just understand that you will have to adjust your gears and brakes if you swap wheels between a 142 and 142+ wheelset.
Specialized/Roval moved the cassette out by 3mm and the disc out by 2mm so they could move the spoke bed further apart to make a stiffer wheel...
Use the wheels, you'll have no issues...
You will not have to adjust brakes - that side of the hub is the same as a normal 142 hub - only the cassette offset is different.
I run a 142 hope hub in a 142+ frame - no issues at all.
Thanks for the info guys. Seems I need to start looking for a reasonably price 142 frame if wheels don't sell. Is a thru axle frame the only one that will work?
Yes - unless you are running paragon sliding dropouts - in which case you can replace the 9mm dropout with 142thru axle ones.
I suspect there are a few other "normal' frames that can do this kind of a drop out swap - but not sure what.
