2 Quick Tech Questions
Odinson
Two quick tech questions, if y'all don't mind.
I'm putting on a new SRAM NX drivetrain on my bike, which replaces a 2X9 set-up. The current BB is an ISIS drive sealed cartridge variant. After removing the cranks and left spindled lockring, I'm stuck on the drive-side lockring. That SOB will not budge. To my understanding, the drive-side lockring should loosen in a clockwise direction - is that correct?
Lastly, my bike's got a 68mm BB shell. With a GXP BB, how should I place the two spacers that come with the BB?
Yes you are correct. It's a left hand thread. Edit: unless you have an Italian thread BB
As for the spacers that depends on chainline and clearance issues. It a trile and error sort of thing. start on the drive side and once that's sorted then space out the non-drive side untill thee is no lateral play in the cranks.
Thanks, Spoke.
Thought as much. The bike is a 2015 Commencal Meta AM HT, so I don't think it would have an Italian threaded BB.
Guess I'll have to invest in some penetrating lube and serious elbow grease.
Find a friend. Remove the wheels form the bike. Grip the BB tool in a vice, and while your friend holds the BB down onto the tool, use the frame as a lever to unscrew it.
As for the spacers - 2.5mm on each side is a good starting point. Adjust for correct chainline as needed.
