Fox Fork Issues
Sharkcatcher01
Hi Guys,
I sent my fork in for a service and got a call from the shop letting my know that there was a rebound rod that had broken (common issue) and Fox no longer stocks these.
You now have to replace them with the newer parts (which is a very good performance upgrade) which takes my service from quite expensive to very expensive in 1 go.
The guys at the shop have given me a good deal on this new part, and while i understand that it is a good upgrade, i never had a problem before hand so i'm in no rush.
Onto the question, does anyone know where i can get this part? A broken fork that still has this, shop or i'd be willing to bring it in from abroad?
Attached the pictures of said part.
Thank in advance.
Hi Guys,
Thank in advance.
Perhaps look for a second hand fork with stanchion wear; there won't be much other use for it, so it should be cheap...
That's a CTD Evolution cartridge, and you're better off without it. If you can find a 2014 or 2015 cart that's the same size, go for it - but I'd highly recommend you go for the FIT4 Performance upgrade, even if you have to eat beans on toast for a bit.
Thanks Droo, appreciate the help.
