Under R10000 Beginner rider
Kobus Smit
Hi
I have seen a few post and tried my level best to understand the gear and what is better than this one over that one.
I have three MTB in my sights
scott aspect 930
Frame
Aspect 700/900 series
Alloy 6061 DB / Performance geometry
Internal cable routing
Fork
Suntour XCR-RL-R
Remote Lockout / Reb. Adj.
100mm travel
Headset
GW 1SI110 OE integ.
Rear Derailleur
Shimano Deore RD-M592
27 Speed
Front Derailleur
Shimano FD-M3000 / 31.8mm
Shifters
Shimano SL-M370-9R
R-fire plus
Brake Levers
Shimano BL-M315
Brakes
Shimano BR-M315 / Hydr. Disc
SM-RT10 CL Rotor / 180F/160R
Crankset
Shimano FC-M4000
40x30x22
BB-Set
Shimano BB-ES-300
Cartridge Type
Handlebar
Syncros M3.0 / 720mm
black / 31,8mm / 12mm rise / 9° BS
H'stem
Syncros M3.0 / 7° / Black
Pedals
Wellgo M-248DU
Seatpost
Syncros M3.0
27.2mm / 350mm / Black
Seat
Syncros M3.0
Hub (Front)
Shimano HB TX505
Hub (Rear)
Shimano FH-TX5058
Chain
KMC X9
Cassette
Shimano CS-HG200-9 / 11-34T
Spokes
14 G / stainless / black
Rims
Syncros X-20 Disc
32H / black
Tires
Kenda Slant 6
2.1 / 30TPI
Approx weights in KG
14.04
Titan Expert 29er Mountain Bike (2017)
Frame: Titan Hydroformed X7 Disc Frame
Fork: Suntour XCR Air 100MM Remote Lock Out
Shock: NA
Shifters: Shimano 27 Speed
Derailleurs: Front: Shimano M190 | Rear: Shimano Altus
Crank: Shimano M131 42/34/24T
Brakes: Shimano M315 Hydraulic Disc
Rims: Titan 29R Disc
Hubs: Alloy Disc
Tyres: Titan Tubeless Ready
Or
Marida big nine 300
matt blue (green/black)
FRAME SIZES 15"17"19"21"23"
FRAME BIG.NINE TFS
FORK SR 29 XCR air LOR 100
DERAILLEUR FRONT Shimano Alivio
DERAILLEUR REAR Shimano Deore-9
SHIFTERS Shimano Alivio rapidfire
BRAKES Tektro Auriga hydraulic 180 / Tektro Auriga hydraulic 160
CHAINWHEEL Shimano M4000 octa 40-30-22 CG
CHAINGUARD attached
CHAIN KMC X9
HUBS Formula Disc / Formula Disc cassette
RIM Merida Big Nine comp D
FREEWHEEL Shimano HG200-9 11-34
TIRES Maxxis Ikon 29er 2.2 fold
SPOKES Black stainless
HANDLEBAR STEM MERIDA Comp OS 6
HANDLEBAR MERIDA pro OS 680 R12
HEADSET FSA NO.572/62BP-1
SEAT POST MERIDA comp SB12 27.2
SADDLE Merida Sport 5
PEDAL XC pro alloy
WEIGHT 13.20 kg
I can get all three in the region of R8999 -R9500
Your input is valued!
out of those three - buy the merida
on a hardtail the fork is what you buy and the drive train etc is about the same on all three so go with the best fork(which being an air fork is a kilo lighter than the others also )
