Rockshox poploc not working
Fred_MTB
Does anyone know how difficult it is to repair spring for rockshox recon silver remote lockout as it does not pop back into unlock position and you have to manually turn dial back when pushing Pollock button , should still be under warrantee but fed up with taking it back to get it fixed after I use it . Hoping to be able to fix at home when doing basic checks etc after riding . Maybe if anyone knows if it is possible to change remote lockout to manual system at the fork to get rid of constant issue . Problem is definitely at fork and not with Poplock switch
Has been back to great lbs but seems to be common issue and will rather either change to manual lock out or learn to fix spring
The compression damper needs a slight modification - the tolerance between the spindle and bushing in the topcap is too tight.
1 x 2mm hex, 1 x 24mm socket, 1 x lathe and about 15 minutes.
  • 3 weeks later...
Took my bike to Stoke , they serviced front fork and rear shock and checked everything .
Tested bike today and feels amazing Thank you Stoke
Good to hear it's all working properly, thanks for the shout out  :thumbup:
