11sp Cassette and Freehub Compatibility
Kalahari Vegmot
So, I've been thinking of going 11sp, but I've got a 10sp mtb hub.
As far as I know, you need to have an 11sp specific freehub for the cassette to fit, but then I read on Ebay and CRC that you only need a new freehub if you want to go road 11sp, but that 11sp mtb cassettes fit on 8/9/10sp hubs as well.
Is this true?
Edit: Grammar
  • Replies 36
Partly true.  Some 10 speed road free hubs can be machined to fit 11sp cassettes - you need to remove 1.8mm off the freehub shoulder.  Some MTB cassettes are made to fit on a 10sp body by "dishing" the largest gear on the cassette so that it sits closer to the spokes than would be the case with a road cassette.  Campy did this on their 11 speeds, that is why the spacers vary in thickness and they all fit on one freehub size. In general though most 11sp cassettes are made for 11 speed freehubs.
Any 11 speed cassette with a 11 teeth small cog should fit on a regular shimano/sram free hub. If you are looking at a 11 speed cassette with a 10 teeth small cog then you will need to replace your free hub with a sram xd driver.
Thanks, I think 36x11 should be fine...
So instead of buying an xd driver for sram 1x11 can you just buy a 11 Shimano cassette. Am presuming that a 11 speed shimano Cassette is compatible with a SRAM 1x11 xo everything else ?
Definitely. Shimano and Sram cassettes and chains are 100% compatible
