Constant brake noise & vibration
Johnny 55
Hi guys. I recently bought a second hand mtb. Its got avid elixir5 brakes on. The front brake works perfect, the back brake keeps on making these awfull sounds when I brake & its not the sound you hear from a wet just washed brake. The bike vibrates alot also especially the back when I brake.
I replaced the rotor and the pads and also got all the seals replaced in the caliper. Pistons release same time so.I dont know anymore. Maybe the hub or the rim is bended, or maybe the frame.
Please help.
Thanks.
There could be a plethora of culprits like, qr, wheel not true, hub bearings, duel sus pivots, crack in the frame...etc
What bike is it?
Avid brakes do not squeal or vibrate if properly set up and aligned.
Have had 5's for years and won't replace them they're great.
Just remember you can't service xt's dis gooi weg and replace.
Avids are serviceable.
If you have a proper bleed kit not much can beat them.
Please help.
Thanks.
Maybe the wheel bearings are shot. This could also cause the disc not to track straight and true under braking.....
Avids are serviceable..
Yes but the service kits are so expensive that even if you do it yourself, the cost for a full overhaul including lever pivots, master cylinder and caliper with new pads comes close to the cost of a brand new brakeset. BTDT
