Bike tire carcass thread comming loose??
Theunissa
Good day all i have a maxxis crossmark that i run tubeless. I took a snotplug out today to replace it with a patch. While i was pumping the tyre back up it blew out where i put the patch in. So when i opened it is saw that the hole became a tear i then put some more rubber solution and a bigger path which also started leaking tge tyre also developed a bubble. When i took it off again i saw the thread that holds the carcass together looks like it has started to devolve. I have temp sowed it back together. It seems that the rubber solution damage tge thread?0b80fcea316078fe73f7cfb8dd07c7e1.jpg
Stans + maxxis = delamination
Patching it probably aggravated the problem
Sent from my HUAWEI VNS-L22 using Tapatalk
i dont use stans use fug it which is water based
