Swift Drone rear clearance issue
Robo
Is the wheel centred in the drop outs?  Sounds like it's been fitted skew.
either that or the frame is squiff.
the other thing you could test is to take it to the northern hemisphere and see if it rubs the other side
Cant quite recall but isnt the drone the TT frame? those normally have adjustable dropouts so maybe need to adjust the wheel back slightly, other than that its probably just wheel flex.
